Capacitor does size matter?
Username: Blindmp2
Post Number: 22
well if u have a big capacitor that has more than the amp that ur using is there any danger would it harm it?
Username: Minime80
Post Number: 32
No, the amp only pulls what it needs from the cap.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7472
a capacitor that has more what than the amp?
a capacitor only stores current then releases it if voltage rails drop.
what you should look at if using a capacitor at all is the capacitance, voltage rating, and ESR.
http://www.wickedcases.com/caraudio/capacitors.html
