Wiring
If I am going to run two amps wiht a capacitor, do I need to have two distribution blocks? one for the power, and one for the ground? Would i run the capacitor just like another amp?
Username: James1115
Wilton, Ct
Post Number: 1520
go to the cap first and from the cap to your amps!
Username: Terps297
Potomac, MD USA
Post Number: 36
i'm pretty sure your not supposed to run the ground wires through a dist block, hopefully someone else can back me or correct me
Username: Invain
Michigan United States
Post Number: 1272
I doubt it would be the best idea. I've never seen anybody actually try it.
How do you ground all three then (amp, amp, cap?)
Username: Invain
Post Number: 1348
Just ground each seperately...
Is there a difference in "ground" and "power" wire? Instead of buying amp wiring kits it would be a heck of a lot cheaper to just by a big spool.. But can i use the same type wire to run my ground and power??
