Re 15" box???
Username: Colinjay18
Houston, Tx Usa
Post Number: 25
i just got my 15" x.x.x. and need to get a sealed box built for it. can anyone here give me an idea on the price? i don't need anything fancy just a good quality box. how much are they?
Username: Dankman
Granger, Indiana United States
Post Number: 62
Hey how much was that RE 15 i wanna get one of emm i got a Hifonics BX1500D amp and i think if i get a dual 2 ohm x.xx it'll work great, have you heard one of these. I've never used only one sub and im worried about the bass, im a bass head and would one of these in a SS or ported box beat really loud like in the 140 decible range? And the box should cost you about 250 custom built
Houston, Tx Usa
Post Number: 26
the sub was $435 shipped. i've never heard one either, i was going to get a 13w7, but after reading into the x.x.x. i chose it. i can't wait to get the box. i went to a few shops today, 2 of them told me $150, basic box built to spec with 1.5" front baffle. one told me $100 but i don't think they do the quality work like the others. another told me $200, but i would have to leave my car there for a few days, don't know about that.
Username: Dankman
Post Number: 64
Yeah go to a place that sells like JL or Eclipse or all the high end stuff and have them build you a box. can you post where you got the sub from so i can order mine haha i cant find a place to buy these things
Houston, Tx Usa
Post Number: 27
www.reaudio.com
Username: Dankman
Post Number: 65
you ordered offline or did you have to call them?
Username: Dankman
Post Number: 66
Brb gotta go get some Budah!
Houston, Tx Usa
Post Number: 28
i called them, gave my mailing info, then credit card info and that was it. took about five minutes. i called on a friday and recieved it the next monday. little over a week.
Username: Rob_brown
Post Number: 149
i have a 15" X.X.X and the box is getting installed in my car tomorrow, i got the spec forwarded to me from someone at RE and it's 4 cubes tuned to 30 hz. That's the sq ported box. The sealed is 2.5 cubes i think. not sure, i don't have the paper anymore, tell me what you think, when you get it in, i'll post up in the next couple of days and tell you how it sounds.
Username: Dankman
Post Number: 67
Thanks man thats exactly what i want to get, cant wait to see it
