Which system....kicker or audiobahn
wassup i was jus wonderin what yall thought would be better...
2 12" Kicker Comp Vr's in a sealed box w/ around 440 goin to them.
OR
2 12" Audiobahn high excursion subs w/ 700 to them?
what would produce the best SQ and which do u think would be best?
Username: James1115
Wilton, Ct
Post Number: 1477
Kicker
Username: Carguy
Post Number: 1674
You might want to check out the sub's spec. Some of them are over rated.
Look for sub's sensitivity of 90db or higher, freq range, magnet weight/size, voice coil size.
alright thanks..i have heard some bad things about audiobahn..why dont they have a good reputation?
Username: James1115
Wilton, Ct
Post Number: 1481
well the problem is that they over rate their products and due to that people tend to blow their subs and cook their amps. I dont like them at all but their are some people that swear by them. I would go with Kicker 1000000 times especially the comp CVR's they are kickers best sub in my opinion before I bought anything made from audiobahn.
Username: Jmloughrey
Farmington, CT
Post Number: 961
yea go kicker...you'll be happier
nick_sq
kicker kicker kicker kicker kicker kicker kicker kicker kicker kicker kicker kicker kicker kicker kicker
Username: Taylor17
Kopperl, Texas
Post Number: 808
Don't like Kicker. Most of audiobahn's stuff is crap, except for there amp's, and a few sub's.
I would say go with Audiobahn, but you want sq, and that's something Audiobahn doesn't have! They git loud, but don't sound good at all.
What Audiobahn sub's are you looking at?
