HO alternators
Username: Rob932
Post Number: 8
I want to get a new ho alternator but i looked at 4alterstar.com but couldn't find one big enough to fit my car. is there any other good websites??
Username: Krijgy
Smithfield, Virginia United states
Post Number: 70
check with aldo. go under the accessary forum and ask again. he is how i got my 200 amp alt. he is in florida, but he will ship it to you.
Username: Invain
Michigan United States
Post Number: 1040
Also try www.motorcityreman.com If you can't find the right size for your car, email them and they could make a bigger one. Their conna make a 160 amp for me.
Username: Solacedagony
New Jersey US
Post Number: 280
I sent two or three emails to 4alterstart.com and I never got a single one back. Who is this guy you talked to Krijgy?
arsonicconvergen@hotmail.com if you want to email me.
Username: Krijgy
Post Number: 74
i posted my issue under the accessories forum and a man named Aldo responded and he works for S.G.S. in florida. he rebuilt my alternator from a 105 amp to a 200 amp alt. it is the exact same casing and bracket form. all i had to do was to bolt it in, and run bigger wires. i can try to bring him to this post if i can.
somethingredicolousihavetomakeup
if i am running 1200 watts in a 1991 jimmy will i need a new alterntor? If so please tell me anything else i will need to ensure that my subs dont blow, or my battery dosent die every other time i start it.
New Jersey US
Post Number: 282
Can you give me his email or phone number or however you contacted him? And how is your alt working for you? Good?
Username: Rob932
Post Number: 10
i just ordered a special order 200 amp alt from motorcityreman.com thanks for the help
Username: Invain
Post Number: 1059
Cool, I hope it works good for ya.
Username: Subfanatic
Walton, Ky
Post Number: 574
yea im getting a 150 amp alt from motorcityreman...thats the biggest they said they have for my neon...is that going to be enough??
Username: Invain
Post Number: 1061
It should be ok.
Volvo 2NT
I need a new alternator for my volvo, anyone know of a company that i can get one from? My is done, it sounds like a airplane whne i drive.
Username: Suleman36
Post Number: 113
IM looking for HO alternator for my 97 camry. www.mralternator is the only place i could find one that has it for me.
Username: Invain
Post Number: 1170
did you try www.4alterstart.com
Username: Suleman36
Post Number: 116
yeah and they had them for hondas but not toyotas.
