Clifford Matrix RS3.5 Remote problems
Username: Pbpippen
Hi,
Yesterday I dropped the remote in a puddle by accident. I dried it with a towel but it still wouldnt regain power. I then used a heater to heat it up and it started working again. The car detected it and it was running fine until I was going home when it started to turn on the remote start on and off by itself constantly. I took out the battery and then put it back in and pressed a few buttons on the remote and it wouldn't detect the alarm again. Then I thought lets see what happens in the morning. I woke up and put the battery in, every function seems to be normal, but the problem is the alarm won't recognize the remote. I tried to do the learn routine again, but it failed. Any suggestions?
Thanks,
Pippen
