Need help with MOSFET amp
Username: Sencesync
Hoodsport, WA U.S.A
Post Number: 12
i need help. one, what does it mean by MOSFET (im new to this area) and no not as in the actualy meaning of each letter. what i want to know {two} does it have to do with the Ohms, considering all MOSFET amps i look at do not give an ohm rate. im getting two PB1836GX and i dont care what anyone thinks about Pyramid, i have been using thier equipment for a while i think its quite nice. can anyone help a newB to this area?. if anyone can just please tell me the ohm rates that a PB1836GX will play at...
Username: Sencesync
Hoodsport, WA U.S.A
Post Number: 13
on another piece of info and something i need to know...., how many amps do each of these pull? im integrading these into a Pro audio system and i plan on using one of those rackmount power supplies they make for this piticular setup. its a 50amp racmount powersupply that is a voltage variable from 12-15 volts, supplies 45amps Continues and surges at 50. will it be able to power the PB1836GXs fully? cause im gona need thier full potential..
