Will it sound good?
Bluejays99
I have a Dual Ported Q Logic Enclosure. I am going to get 2 JL 12 W3v2 with a 500/1 amp. I was going to put it in the Q Logic box, but will it sound good or should i get a new box.
Username: Nnnnick_b
Nc Usa
Post Number: 125
go sealed if u want sq. If you are dead set on a ported box then make sure the tuning is between 28 and 31 htz for sq. I would go sealed personaly. If u listen to rap then a 35 htz tune would be fine for u as well.
Username: Nnnnick_b
Nc Usa
Post Number: 126
If u go ported make sure to use the subsonic filter on the 500/1
Username: Jonathan_f
GA USA
Post Number: 3381
Those Q logic ported boxes are tuned HIGH (around 45) and are very small. With those subs, I'd recommend 2 cu ft net tuned to around 32 hz for SQ/SPL.
Username: Nnnnick_b
Nc Usa
Post Number: 127
d@mn that high(ouch)
Username: Nnnnick_b
Nc Usa
Post Number: 128
And thats 2 cuft per sub.
