Subs info..
Username: Dsgbthuglife
how many 4ohm subs would it take to handle a 1ohm load?thanks..also what would the wirring diagrame be like?
Username: Cenus
Hicksville, Ohio Usa
Post Number: 25
http://www.jlaudio.com/tutorials/wiring/index.html i don't know if this helps but i hope it does
Post Number: 7
is there a diffrence in 1.33ohm and 1ohm?or are they both 1ohm load?thanks..
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 19
both are really low resistnce, but the 1.33 has .33 more ohms of resistance. not enough to matter much unless your trying to get power to compete or something
Username: Taylor17
Kopperl, Texas
Post Number: 672
Most sub's aren't the exact ohm's they say they are. 1.33 is basically 1 ohm.
Post Number: 13
so i wouldnt loose any power right?with 1.33ohm on the 1ohm amp load?
Username: Taylor17
Kopperl, Texas
Post Number: 682
No, not really. Unless your competing, you won't notice much of a difference.
Post Number: 15
thanks..
Username: Taylor17
Kopperl, Texas
Post Number: 689
No problem, glad we could help.
