Enclosure question
Hey guys I have a question. What is the best stuff to use to seal the inside of an enclosure ? Also if I want to double up the front baffle what should I use to stick the front two piece's together ? do you know of any good box building site's that I can go to for reference ?
thanks so much ya'll
Username: James1115
Wilton, Ct
Post Number: 1208
I believe crutchfield has a good demo on box building but I am not sure. Box building is not my fortay but I am sure someone in here can assist you without a problem.
Username: Theelfkeeper
Stockbridge, GA USA
its not really that important to seal the box completely, but if you want to you can use silicon (let sit overnight, fumes can damage subs) or if you wanna dampen the box, a lot of people use fiberglass resin or dynashield.
you can double the front baffle, just make sure they are secure and won't rattle together or anything
do some research online, crutchfield has info and JL had a tutorial about boxes on their site
