Need help with this.
basshead
Alright i have decided that Im going to get two twelve inch v-maxes and power them with my brutus 1500d amp that i already have. The v-maxes will be in a ported box. I have two questions really. I have heard a lot of systems with bass that just hits deep and you can really feel it, thats the kind of bass that I want, which is why I am upgrading my system. I was just wondering if my system would be able to beat that hard where you really feel it deep in your chest in my 1997 taurus or if I should save up more money and get better subs.
My other question I probably should have posted in the speakers section but I just decided to put it with this one, but I don't know much about component speakers so I was just wondering what kind of speakers I should put into my car with this system. Im not looking to spend more than 150 dollars on components. All help is appreciated.
Username: Rob_brown
Post Number: 145
Ii think taurus's come with componet sets stock because my dad has a componet set in his 94 Taurus SHO. So just find the speaker size and read around. You could look on cardomain.com and see what people have in theirs.
Username: Invain
Michigan United States
Post Number: 764
Measure all the speakers on your car first. Tell us the sizes, and are you planning on running that off a head unit, because 150 isn't gonna cover components and an amp to run them.
Username: Basshead
Would it sound good running off of the head unit or should I get an amp? I just meant I wanted to spend like 150 on the actual speakers Ill spend more on an amp to power them if they don't sound good off the head unit.
Username: James1115
Wilton, Ct
Post Number: 1117
what size speakers do youhave? I dont recomend running components off a deck you need a amp to run them.
Username: Basshead
I looked it up on a ford site and it said that the speakers are 6x8's in the front and the back.
Username: James1115
Wilton, Ct
Post Number: 1127
go to www.crutchfield.com and look up a few different 6x8's pick one in your range and go to ebay and see what you can get them for "buy it now"
Username: Basshead
alright thanks
