AMP Wiring HELP AND QUESTION
Username: Joe55
Is there any difference in brands of wiring kits??
also....
I amp planning to install a:
RF p3 sub (400rms)
RF p5002 amp (Max 1500, RMS 500)
to 02 Honda CIVIC....Do u guys think I would need an electrical upgrade, stiff wires, alternator, capacitor, etc...?? I dont think so but i wanna double check..
if thats all you want to put in your car, it should run it with no problems. now if you find that your car is not running smooth and the lights are dimming really bad after you install the system, then go for an alternator upgrade.
in terms of wiring kits, they mostly all do the same. the main difference I see is the strand count in the power wires. the more strands, the more flexible the wire and easier to install. I highly recommend checking www.knukonceptz.com for wiring kits.
Username: Joe55
Do u guys think i need a cap for this or is the stock alt/battery good enough...i dont feel like spending xtra money on cap??
Username: Treeguy2oo4
Phoenix, Arizona USA
I belive a cap is a good thing to do any ways. and is you look real good you can get them a low cost!
Cash Deficiant
Is that english?
Better off upgrading the electrical system with a high-output alternator than to go with a cap.
althought, you should be fine with that setup.
