Finally made up my mind on a componant set! check it out
Username: Suleman36
Post Number: 280
I finally found a componant set in my price range of $300 and went with the Image Dynamics CXS62 Componant set. It cost me $305 total shipped. Just waiting to get them. They are 2 ohm and 150 watts rms each. Im gonna run them off my PPI Art 300.2 amp that puts out 150 Watts RMS x 2 at a 2 ohm load. Perfect match. Cant wait to get it installed and hear them.
Username: Jwbulger79
Florida
Post Number: 225
dude, that'll be sweet. 2ohms huh? that seems like a great idea for a comp set. any drawbacks? i dont think i've ever seen a 2ohm set, 3ohm, but never 2ohm. cool.
Username: Suleman36
Post Number: 283
same here j.w...i couldnt believe it. Isaac hooked me up with that info
Username: Tragedy
San Jose, CA
Post Number: 68
Yes the image dynamic components are available in 5.25 and 6.5(oversized 7") both in either 2 or 4ohm and they are a great set of speakers. You will enjoy them
Username: Suleman36
Post Number: 286
Installing wise..it'll still fit even though its 7"...do i need anything special for this installation to be done right except for Dynamat?
Username: Zapcod
Cool...I will be getting the chamelons(did I spell that right?)from Image Dynamic along woth their IDMAX 12' sub using all Zapco amps...you have great taste :-)). Post when you install and break them in and let us know how they sound. You may nees spacers in the door for the 7" it's easy and cheap.
Username: Suleman36
Post Number: 289
Yeah ill definetly let you know..Im not sure what exactly ill need to install these..but i wanna get the most out of them.
Username: Audiobahnsound
Tiffin, Ohio USA
Post Number: 9
Hey can you find a link for me i would like to get 2 pairs of the 6.5 componets for my ride
Username: Tragedy
San Jose, CA
Post Number: 71
do a search for csx64 (4ohm) or cxs62 (2ohm) on the internet and try and find the best price. Then go to cardomain.com and put in a best price request for the component set. Cardomain is an authorized retailer (i think the only one).
Username: Suleman36
Post Number: 296
Thats right chris..TraGedy is right. I got mine for $305 free shipping and a discount.
Florida
Post Number: 255
chris, why 2 sets?
Tiffin, Ohio USA
Post Number: 10
front door, rear side panels
Username: Suleman36
Post Number: 298
I think one set of those powered at 150 rms which it can take should be plenty for the front stage. Im just gonna put my 2 13w6v2's in the back in a slotported. thats all my drivers..hopefully the subs wont take away from the front stage
Just Deep
MO : Good Choice
Chameleons are great that too in 2 Ohm configuration.
What Subs and Head Unit are you using.
Just Deep
MO : Good Choice
