Would this work
i have 2 kicker comps svc 8ohm if i wire them in parrell they will recive a 4ohm load right but the amp i have says 2ohm stable mono, would this set up work or would i have to wire my subs differently
Username: Taylor17
Kopperl, Texas
Post Number: 659
It will work. That just mean's that the lowest ohm's your amp can handle is 2 ohm's.
ok i just figured it up if i run the subs mono off the amp i have at 4ohms the amp will be putting out a little over 200 watts but my subs are rated at 150 RMS do u think this would be over powering the subs too much since there so small
ohh ya the subs are in a ported box if that makes any difference
Username: Invain
Michigan United States
Post Number: 941
Is that 200 rms total, or to each sub. Each sub is 150 rms, correct? You should be ok, I would just be careful.
it says in the manual @12.5 volts 4ohm mono 150 watts, @14.4 volts @ 4ohm mono 225 watts so i think the 150 is rms and the 225 is peak wattage
Username: Taylor17
Kopperl, Texas
Post Number: 673
If your amp is rated 200 watt's rms times 2 at 4 ohm's, you will be fine.
