Adjusting amp
Username: Xxkmfdmxx
St. Petersburg, FL USA
Post Number: 348
I have a MTX 1501D set up to two 13kv.2's, Should I have my Freq, eq, and gain at any certain level for these subs? I know I shouldnt go too high on gain, But what do I set the freq knob at? as well as the eq knob?
Username: Nwdmax
Post Number: 21
http://www.mtxaudio.com/caraudio/products/manualsQuickInstall/amps/Thunder_421D_ 801D_1501D.pdf
read your owners manual or go here to see what you should do
Username: Xxkmfdmxx
Post Number: 351
Knew about that manual....It just basically says put them up untill you hear distortion. Which doesnt seem right cause I can put them all up all the way and not hear it distort. I have the gain now at half way. What should I set the freq to, How many hz?
