Waht goes in this slot
ok on my amp there are three little things to hook wires into....one for ground, then power, then one that says REM??? what does that maen? i got a little spool of wire in my amp kit that says remote turn-on wire...is that what goes there and waht does it hook to? on the diargram in the box that game with my amp there is a picture of a wire going from taht REM slot to the radio, but all that i no of taht goes there are my rca cables.....right?
any help at all will be appreciated
Username: Insearchofbass
Post Number: 1103
its called your remote wire the wire is usually blue on the back of your radio.........it is what tells the amp to turn on
Post Number: 1104
in other words blue wire from deck to remote turn on the amplifier and screw it down (all this with power off to everything)
Post Number: 1105
also your rca's are what provide you with sound from radio to amplifier
