Amplifier mono at 4 ohms need it for 2 ohms for 1 sub
Username: Crusacargen
CA US
I have 2 single 4 ohm voice coil audiobahn 550 watt rms excursion subs. I am running each sub with its own Verge 300 mono amp which runs at 4 ohms to get 190 watts rms. What do i do in order to a single sub at 2 ohms with this amp.
Username: Geekbike
Post Number: 43
You can't do it with a single sub. It can be done with both your subs if they are wired in parallel though.
CA US
Ok since u said that. I was wondering if i have 2 amps and 2 subs how can i wire that? Do I just split the wiring to both in order to get 2 ohms running for each amp?
Username: Nnnnick_b
Post Number: 16
u cant. In order to drop the impendence down to 2 ohms u would have to wire both the subs in series to one amplifier. but then u wouldnt have a use for the other amp.
