Help<<<
Username: Volsrule2069
i got the streetwire amp kit, and it shows on the diagram thing 3 big wires, one from battery to fuse from fuse to amp from amp to ground, i only got 2 big wires, the big red one has a metal loop on it like the one that goes to the battery....am i supposed to cut that part off and use that to ground it??
Username: Jrz126
Erie, PA USA
You cut the red one and put the fuse in line with it, (connect each side of the fuse to each end of the cut). The other wire should be a black wire which is used for the ground.
