Please rate my final setup
Username: Ffxdevilarms
Post Number: 201
On a scale from 1-10 how would you rate my setup.
Nakamichi CD-400 HU
Focal Polyglass Slims for front doors. Only really good 6.5 that is not too deep.
Zapco Reference 200.2 for the focals
2 Adire Audio Shivas
Zapco Reference 500.1 for the Sivas
MDF and Fiberglass Enclosure with 1.5 cubic feet per sub with polyfill.
Symbilink cables for both amps.
Post Number: 208
I changed it up a little bit. Instead of the focals i am going with the DLS UR36S 3-way component set. I am the only one that will be in the car so i will be mounting the tweets and 2.5" mids on the dash/a pillar, and the 6.5 in the door. I will not be using the fiberglass enclosure, but i will be using the same specs on the box. I will be using the same amps, cables, and HU. What would you rate my setup?? I am going for good SPL with Extreme SQ. All for around 1775.
Username: Jonathan_f
GA USA
Post Number: 3279
All the equipment is great. As far as the subs, for extreme SQ, I'd recommend the Image Dynamics IDQ driver in that price range. Even Dan Wiggins (president, founder of Adire Audio) admits the IDQ is a better SQ subwoofer. 2 of them would still get loud too, and they work better in smaller enclosures. You could also consider a single sub such as the Eclipse Titanium, JL Audio W6v2 or W7 (although pricy), Image Dynamics ID Max, Resonant Engineering X.X.X., Adire Audio Brahma, etc. You'll get great output and SQ to match it. I know slim components are hard to find, those DLS will be great. The Morel Hybrid series are great and slim as well if you want another option to look at. About those 3-ways, while they're great components, the way you are going to install those 3-ways won't result in the best sound quality. Mids are the most crucial speaker to get the pathlengths right, and mounting them in the dash will result in a soundstage that is inferior. The imaging will pretty much fall apart, especially if you were to use factory locations. 3 ways aren't really better for sound quality, especially if they aren't in an optimum install (which is VERY hard to do in most cars), most competitors stick to conventional 2 ways in kick panels. 3 ways with the mids and tweets in the dash and midbasses in doors (without processing at least) will result in what is called a "layered" soundstage, where certain frequencies such as highs will be at eye level, mids will be lower, and midbass will be at your feet. It doesn't work well and it doesn't image well. The only time tweeters work VERY well in A pillars is when you have the crossover to do so or the processing to make it work. Typically, higher order (such as 24db/oct) works best for this, and generally tweets need to be crossed over around 6k. Doesn't sound like a problem, but it is hard to find midbass drivers that will play that high, plus most factory door locations are so off axis that they don't allow good frequency response past around 2-3khz.
I really can't make a recommendation until I know what kind of vehicle you have. The equipment you've chosen is all top notch, but that doesn't necessarily mean it will work best in your application. In most vehicles 2 ways give better results than 3 ways do simply because they have fewer crossover points and less pathlength differences, plus you have more room to get the install right. Since you are willing to work with fiberglass (or I think) you could make a killer kick panel setup. Install is 90% of how a system sounds, the best drivers in the world won't work their magic unless they are installed well. They may sound good, but the imaging will seem to just come from the door locations and won't have any definition or life to it. Sounding good and having an accurate system are totally different, it's easier to have a system that sounds good than one that images well. Imaging brings the system to life.
Post Number: 210
it is in a 2003 monte carlo. I allready ordered the shivas, and i really want those. As far as the comps, i am getting a really good deal on them. They guy i am buying from i met on ebay and owns a shope and is giving me everything at really low prices. At the moment he said he would make kicks custom for my car, but they would cost 200 dollars, i dont want to nor do i know how to make them. He said he would fab holders for the 2.5"'s for me for free so i figured i would try it out, and if it doesnt sound right, i would have him make me the kicks.
Post Number: 211
I am allready way over what i planned on spending an do not really want to spend that 200 dollars on them just yet. At first i was going to spend 600, i am now at 1775 without the kicks.
Post Number: 212
This was posted on an SQ champions own forumn, so i dont know who is more correct on this topic. I am totally confused.
"If you want your car to image properly from both seats (with a defined center image and located in the correct location), the midrange drivers MUST go as far away from your ears as possible. So, sit in your car with a tape measure, and measure the distances from the possible locations available for mounting the mids, and your ears. Try all combhinations that are in front of you. In most cars, the kick panel is the furthest away. In some wierd instances, the dashboard is equidistant, but rarely father away than the kick panels. So, the answer the question, put them as far away from you as possible, even to the point of cutting metal and welding enclosures and whatnot into place.
Now, if you want a car that images good from only one seat, put them at eye level on the a-pillars. Then use time alignment to bring it all together. This is what we are doing in Brett's Rodeo. He will compete in Pro Street, which is only judged from one seat. So, we will be placing the mids and tweeters at near eye level, and using electrical manipulation to make the imaging right."
Scott
_________________
President, Buwalda Hybrids
Atlanta, GA, USA
Post Number: 213
This was posted by a SQ champ. I am not totally confused as to why there is a difference of opinion.
Scott
_________________
Atlanta, GA, USA
GA USA
Post Number: 3280
Same thing I said, basically. You can make it work with processing (time alignment). Without time alignment imaging won't be good at all. It's just that you don't have a head unit that will provide time alignment, the Eclipse 8454 and Alpine 9835 will do that for you. The Eclipse 8454 is the only head unit that will allow you to do that with a 3-way setup, and they have a fixed out that you can use on the subs. You can also buy processors such as those from Alpine that will let you do that.
Post Number: 214
Are they expensive???
Post Number: 215
I think i have made a decision, i am going to go with DlS's highest end 2 way 6.5" set, the Iridium 6.2's. Simpler to install and overall it will be cheaper as i can put them in the factory locations in the door.
GA USA
Post Number: 3291
Those Iridiums will give better results with the way you plan to install them. Great set of speakers.
Post Number: 218
I am getting a really good deal on them, before i tell you, what do you think is a good deal to pay for them???
GA USA
Post Number: 3292
Can't remember the exact retail on those, I'd say you'd do good to find the 2 ways for around $500, cause I believe (may be wrong) you can get them around $600 shipped.
Post Number: 219
I am getting them for around 400-425 shipped.
GA USA
Post Number: 3293
hehe sweet :-) I guarantee they're worth every penny.
Post Number: 222
Ok, i canceled the order on the shivas, because they are on backorder for a while. Anyways, for $350, what sub or subs can i get that will give me the best sound quality and still get really loud that will work best with the amp tha i chose??
GA USA
Post Number: 3295
I really like the Image Dynamics subwoofers for SQ purposes, with 500 watts an ID Max can get loud and sound excellent. It's a very efficient subwoofer. The Adire Audio Brahma is a great sub, and also the JL Audio 13W6v2.
Post Number: 223
Will any of those be as loud as 2 shivas???
Post Number: 224
How about one ID Max v.3 for 290 dollars in a 1.5 cubic foot enclosure??
Username: James1115
Wilton, Ct
Post Number: 925
that is a very nice sub you cant go wrong wiht it. I am sure Jonathan will say the same since thats what he runs in his own car.
Post Number: 225
All i have left to order is the Sub and my comps, which i will order as soon as my credit card arrives this week. the only premaid box that i can find is 1.2 cubic feet by subzone, will that be allright with some polyfill???
Username: James1115
Wilton, Ct
Post Number: 932
I dont know. I would think that you need something a little bit bigger. Remember that with that sub it has to be 1in mdf not 3/4in. The only time I have tested this sub it was in a 1.5 cu/ft sealed and it sounded truely amazing. Maybe Jonathan has tested his in more then one enclosure.
GA USA
Post Number: 3296
Mine is in a 1.3 cu ft sealed enclosure (it's the 12 inch) with about a lb. of polyfill, give or take. It is an excellent balance of SQ/SPL. The sub will offer similar performance to those Shivas, SQ of them is fantastic as well. Low tuned ported (25hz) will offer great results and higher SPL. The good thing about that sub is it is extremely versatile, has a low resonant frequency and offers good results in a variety of enclosures. It's also very efficient and works well even with lower power. I run a JL 1000/1 and really I don't need near what that amp can put out, although the sub will take it.
Post Number: 226
Do i really need to use 1 inch mdf Jonathan??? If you have any suggestions on a cheap box that is premaid that would work well, let me know.
Post Number: 227
Would you take one DLS UR12 Sub over the ID MAX?? I can get the DLS UR12 for $15 over dealer price for only 250 dollars. They guy i am going through is giving me a lot of deals.
GA USA
Post Number: 3303
3/4" will be enough IF it's built well. A little difference won't hurt, a 1.25 cu ft box would be fine. This enclosure would work:
http://www.bigdogcaraudio.com/proddetail.asp?prod=BIG121SLREV
They make good boxes, I'd stuff it with a little polyfill.
GA USA
Post Number: 3304
BTW, optimally you'd build your own and brace it well.
Post Number: 228
What do you think about the DLS?? He would give me a good deal on the ARC Audio Flat Line Piston and the Diamond TDX. Which would you take between the 4 subs discussed?? They are more expensive, so i could only do one sub.
Post Number: 229
Would this enclosure be even better???
text/htmlUpload
BIGDOG.html (43.1 k)
Post Number: 230
Crap, i just realized it was square. Forget the last post. LOL.
Username: James1115
Wilton, Ct
Post Number: 942
Hey Jonathan have you used Big dog before? I read something on them a while back that said dont ever do business with them because many people have paid for items and never recieved them. I have never dealt with them myself and the article I read was just a BS post so your opinion will mean more then what I read.
Post Number: 231
I am thinking that maybe my best bet would be to go with 2 IDQ's since they are suppose to have good SQ, and i imagine that there would be more displacement then the ID MAX.
GA USA
Post Number: 3305
2 IDQs would be great too. SQ is excellent. James, I haven't personally, but I've had a lot of friends use them and they haven't had any trouble. Glasswolf recommends them often as well.
Post Number: 232
One more question, will they be nearly as loud as 2 shivas?? Was i right about 2 of them being louder then 1 ID MAX???
Username: James1115
Wilton, Ct
Post Number: 950
alright I take that back then because I forget where it was but it was a post about bad companies and I believe I saw them on there but it could have been another company with dog in the name I am not sure. And Chris you cant go wrong with Image Dynamics they make great quality stuff. I recomend the IDQ's highly around here.
Post Number: 233
with the zapco refrence 500 amp, would you recommend the Big Dog enclosure that is .88 cubic feet or 1.25 cubic feet per sub. THe subs are 350 RMS, and my amp was checked by their tech like they do with their amps and it was rated at 543 rms.
Username: James1115
Wilton, Ct
Post Number: 954
was that test at 12 volts or 14? I would recomend going with the .88 sealed if you can find it. If you go ported go about 1.75 tuned to like 28 htz. Thats a very nice amp by the way.
GA USA
Post Number: 3311
Zapco rates at 12V, and they underrate their products. I'd bet it was a 12-12.5V test. That amp would be plenty for one or two IDQs, SPL would be similar (a little less) than 2 Shivas, but would require MUCH less box, that .88 is better like James said.
Post Number: 234
Great!!! As soon as my credit card come this week i will order the comps, subs, and box. Then i will be set. Everything else i got through this guy i met on ebay. He gave me so many good deals. He gave me both zapco amps $20 over dealer prices, after shipping. he gets free memphis cable, amp kit stuff, and wiring so he gave me all memphis and metra installation items that i need for my head unit for only $100 including shipping. And of course those Iridiums that i am getting will be from him. He owns his own shop, i can give you his information if you want to get a hold of him. Just let me know.
Don't mean to threadjack but how would yall rate this? Sub- RE X.X.X 15" with ported box. Amp- ED nine.1. Front- Infinity Kappa 42.5i's and Rear- Infinit Kappa 52.5i's. Headunit- Pioneer Premier DEH-P8MP. How does this all sound for a first system?
Username: James1115
Wilton, Ct
Post Number: 961
are you running your kappa's off the deck? anyways all you need in my opinion is a nice 4 chanell amp for those mids and highs but other then that it looks great.
Post Number: 235
i am not getting kappas. I am getting the DLS 6.2 Iridium Components. I am using the Zapco Reference 200.2 amp for them.
Username: James1115
Wilton, Ct
Post Number: 967
I was answering anon's question Chris. Your system is going to be very nice when you are done bud.
Post Number: 236
oh, sorry bout that.
yeah, i have to save some money for an amp. i went way over my budget, with install prices and stuff.
Post Number: 237
Do the 15" IDQ's have good SQ??? I want my subs to get really loud with good sq.
Post Number: 238
I would really love to know because i would love to have 15's if they still have decent/good sound quality.
