Username: Point78 Post Number: 3 Registered: Feb-05
Monday, February 21, 2005 - 17:36 GMT so if the sub im looking at is dual voice coils at 2 ohm when im looking for an amp do i read the rating for 2 ohms or 4 ohms or 1 ohm?
Username: Joe718 Brooklyn,
NY
Post Number: 300 Registered: May-04
Monday, February 21, 2005 - 18:29 GMT If your running one sub that is dvc 2 ohms, your going to need a 1 ohm stable amp.
Username: Sublime420 Ca
Us
Post Number: 53 Registered: Jan-05
Monday, February 21, 2005 - 19:36 GMT thats not true. you can run the subs at 1 ohm, but you could also run them at 4 or 2 ohms. its all in how you wire it.
Username: Point78 Post Number: 4 Registered: Feb-05
Monday, February 21, 2005 - 21:06 GMT how would i wire it for 2 ohms
NY
Post Number: 305 Registered: May-04
Monday, February 21, 2005 - 21:44 GMT if you have one speaker with 2 ohm dvc's, there is no way to leave that speaker at 2 ohms. Its either going to go to a 4 or 1 ohm load. You cannot have a dvc sub and use only one coil that will damge the sub.
Us
Post Number: 56 Registered: Jan-05
Monday, February 21, 2005 - 21:54 GMT not true. if you have a 2 channel amp that is 2 ohm stable, you could wire 1 channel to 1 voice coil, and the other channel to the other voice coil. thats 2 ohms.
NY
Post Number: 308 Registered: May-04
Monday, February 21, 2005 - 22:13 GMT you could do that. Sub caught me slippin lol. Bryce if you do it like just make sure when you tune your gains tune them exactly the same
Us
Post Number: 67 Registered: Jan-05
Monday, February 21, 2005 - 22:37 GMT im not sure about all 2-channel amps, but i have one and it only has one gain knob. so that might not be a problem.
Username: Point78 Post Number: 5 Registered: Feb-05
Tuesday, February 22, 2005 - 05:33 GMT what about if i have two subs
