Basic EQs and XO website?
UCF_Shawn
Hello,
I will be upgrading my audio and wanted to know where I can go to learn basic information about equalizers and crossovers on the web?
Or any help here would be appreciated.
Just for FYI, here's my system. KX1200.1 to 2 15" CompVRs & KX650.4 to Kappa Perfect 6.1's front with JL Audio TR650CXi and XR100 for rear-fill and soft-tweeter fill.
allende5
I don't know of any sites, but do you have any questions in particular?
Username: Glasswolf
Wisteria, Lane USA
Post Number: 7861
www.bcae1.com
lots of info on both crossovers and equalizers of all types.
UCF_Shawn
I just looked at the Kicker KQ9 owner's manunal and saw the wiring diagram I get the basics now. Before I was confused, I thought the number of bands was the number of channels each EQ had.
I still confused on how I will get the correct signal to the specific drivers, i.e. the high frequencies to my stand-alone tweeters? As there's only a pair of RCA outputs per amp. I thought that I would just use the rear channels of the SX900.4 for the tweeters and TR-650CXis to play the higher frequencies, and the Kappa Perfects to play the mids.
