Ground wire, where to connect?
wc
Give me some places to connect the ground wire on an amp.
Username: Jaywolf
i connected mine where my trunk latches. Under any metal bolt would be a good place
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 286
I cleared the paint off under the carpet and drilled a hole and used a bolt. Also make the shortest possible ground connection. This is for high-current amps though. If it is a small amp then durans idea is okay.
wc
Can I run the ground wire out from the bottom of my door so I can connect it to the fram of my truck?
Username: Vaio
Post Number: 30
make a hole on the car for the wire go to the fram of the car and that is a great GROUND that where i have my ground at
wc
So I am going to have to drill a hole then, I cant run it out the door to the frame.
Username: Hdubb
Farmington, Nm Usa
Post Number: 679
no dont drill a hole. just find look under the carpet and find a bolt, usually there are a lot towards the back d=seat area, and just bolt it on there. not too hard, just takes a lil patience
wc
Aight coo, see thats what I needed to know, so just find a bolt and connect it there.
ukmg
So no need to drill hole?
Username: Hdubb
Farmington, Nm Usa
Post Number: 695
no not really. just pull up your back seat and you will find an assortment of bolts just try a few and youll get a good one, eventually
wc
Aight thanks, so under the seat on a bolt is good.
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 358
Make sure you sand off all the paint around the bolt. If you dont, you prolly wont get a good connection.
ukmg
hey what happens if you dont have a good connection?
wc
I dont know
Username: Urshitsuxs
don't put it on any sub-frame areas. You need a good "solid" ground that no other wires are grounded to. Also, with your car running, check your battery voltage. Next, check the voltage at your power and ground where you have your amp installed. The voltages should be real close. If not, you have a bad ground.
wc
What would happen if you have a bad ground, fry your amp?
saffron
EH more like it wont preform up to par and if you crank it to make it preform cheap amps may heat up and fry
ukmg
So a bad ground will fry up your amp
