Q-Logic: Good or Bad?????
ward
Are Q-logic boxes well built and are they worth buying
Username: James1115
Wilton, Ct
Post Number: 1052
I think they are ok but kind of expensive.
Username: Hdubb
Farmington, Nm Usa
Post Number: 814
they are nice boxes, except for the ported ones, hunter no likey, bnut sealed are nice. but you could build one for half the price
Username: Invain
Michigan United States
Post Number: 734
Yeah, they are pretty expensive. If you are carpentry impaird, I would suggest one. You might be able to find other brands that are just as good for cheap too. And no, I really wouldn't recommend any prefab ported box, unless your sure it is exactly what you need.
Username: Hdubb
Farmington, Nm Usa
Post Number: 818
i think thats what makes boxes so damn exspinsive is carpet
Username: Invain
Post Number: 737
lol
Username: Akula_class
Post Number: 10
My Q Logic box wasn't very good. I ended up getting a Memphis box and the difference was night and day.
Username: James1115
Wilton, Ct
Post Number: 1093
yeah like Hunter and Joe said sealed is always easier so you can feel a little more comfortable buying it but when buying proted you have to know exact size and tuning frequency which can make a sub sound like shiot if tuned wrong.
Username: Erik123456
Arlington, Tx
Post Number: 427
try obcon boxes if you can find em
