I have the jl 500/1, whats the perfect match?
Username: Adriand619
San diego, Ca U.s
I currently own a jl 500/1 amp and was wondering which sub would be a perfect match. Would it be the 10w7 or the 13.5w6v2?what do u think would sound louder? Also, or shoould i get two 12w6v2?
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 231
the 13w6v2 would be a good match as would the 10w7 .. cant say for certain but i would say the 13.5 would be louder because of more cone area.. also the 13w6 is said to have better sq
Username: Taylor17
Kopperl, Texas
Post Number: 531
Ya, I would think the 13 would be louder.
Also, just an idea look at the new Alpine type R. It's 500 watt's rms, and look's like it is designed after the type X.
Username: James1115
Wilton, Ct
Post Number: 889
yes the 13w6v2 will be louder and have better sound quality. Personally I am not a big fan of the w7's. They get loud but for the price difference between the w6v2 and the w7 its not worth it when the w6v2 is a much better sounding daily driver woofer.
Username: Suleman36
Post Number: 71
Adrian i own 2 jl 500/1's and have 2 12w6v2's in a sealed box. It sounds great but i wanna upgrade to the 13w6v2's cause i want that perfect match! Itll give you more spl in a ported box too
Username: Suleman36
Post Number: 75
Im thinking about getting the 13w6v2's..anyone else have them..
