Amp on but no protection
Username: Blindmp2
i have a new 2000 digital performance teknique, and theres power but theres no protection and theres no sound coming out, i have 2 1200q and they are not hitting what should i do to make the proctection come on
Username: Kojak28
Augusta, GA USA
Post Number: 18
Protection is a red light that comes on if the amp senses a detrimental failure. Try turning your gains up.
Username: Kojak28
Augusta, GA USA
Post Number: 19
Once the amp goes in to pretection, you will have to shut off the remote(done automatically when you switch the ign off) then turn it back on. Most amps will go into protect before any damages occur.
Username: Blindmp2
well the power light is on but no Protection light and i already turn off the ignition and disconnected it and reconect and still its in protection
Username: Rob_brown
Post Number: 147
is it grounded?
Username: Blindmp2
yes it is ground should i check that?
Username: Kojak28
Augusta, GA USA
Post Number: 22
Are your gains turned up?
Username: Blindmp2
Post Number: 10
yea the gains are up
Username: Kojak28
Augusta, GA USA
Post Number: 25
POwerlight AND protection light on?
Username: Blindmp2
Post Number: 11
powerlight on
protection off
Username: Kojak28
Augusta, GA USA
Post Number: 26
OK. You want your protection light OFF. If it is on that means something is WRONG. If you have a multi meter, check the voltage on both sides of the remote wire(at the amp and at the head unit). Let me know.
Username: Blindmp2
Post Number: 12
oh ok so when its off its ok
Username: Blindmp2
Post Number: 13
i check the remote wire, its okay why
Username: Kojak28
Augusta, GA USA
Post Number: 29
If you check the remote wire at both ends and it is good then you have a signal at the amp. Are you rca jacks good? What brand are they, how old? Do you possibly have another amp? If so you could "bench test" your setup/wiring to see if it is correct. I recently had to gut a system looking for a similar problem. I FINALLY found a crispy wire connector on the inside of the sub enclosure. If by some chance this does not expose the problem, Give me some info on your headunit/rest of your system.
