2 subs/2 amps.. wht NOW?
Ok i kno very little about amps.
I have two kicker l712's, and two boss riot 1500d. I also have a box and nothing else. Wht do i do now? Do i connect the amps together? Can someone please tell me what i do next?
ALSO DID I GET THE WRONG AMP IF I WANT TO GET THE MAX WATTS FROM MY SUBS?
Username: Hdubb
Farmington, Nm Usa
Post Number: 746
do you have a head unit? yoiu will nedd 2 wiring kits. www.knukoncepts.com
you will also need a good fused dist. block. one that is 1/0 gauge to 2 4gauge. so you can run one main power line and just have it split into 2. if you dont have a head unit(cd player), try to get one that has 2 rca outputs. if you have one and it doesnt, then you will need some y cables to split the rcas.
