Ohm Wiring Need a little more help
Username: Xlvnloud
Oklahoma USA
I've understood the most on wiring, but I just got 2 new subs and I think instead of getting dual 2 ohm I should have got 4 ohm like my old subs.. Heres what I have that I want to see about.
My amp is a Kicker kx1200.1 1,2,or 4 ohm. I want it running at 1ohm and the subs are both dual 2ohm is there any way possible that I can get both together to go at 1ohm? If it's not, I might add one of my dual 4ohm subs in and that way I'm pretty sure I can get it to 1ohm. See if anyone can help me out..
Username: Marley289
Post Number: 97
nope you can run it paralell to get 2 ohms or you could run it in series to get .5 ohms i think, and i dunno if that is safe with that amp.
Username: Invain
Michigan United States
Post Number: 626
I woudln't advise running it at .5 ohms.
Username: Xlvnloud
Oklahoma USA
What about with 2 dual 2ohm subs and 1 dual 4ohm? can't I get it at a solid 1ohm?
Username: Xlvnloud
Oklahoma USA
I got 1 Dual 2ohm and 1 dual 4 ohm, does anyone see a way to get it down to 1ohm without me having to add another sub?
Username: Subfanatic
Walton, Ky Usa
Post Number: 223
ok i gotta a question since it pertains to the same thing as this thread lol...i have the same delima...kinda ....i have a eclipse al DVC and it says like 3.1 Little weird horseshoe sign..and my amp is an interfire IB2900C amp it goes down to 2 ohms...how can i wire this sub to 2 ohms?
