Thunder9500 vs. W7
Is was thinking about buying a w7 but mxt has me thing.Mtx claims its better the JL is this true?
Here the link
http://www.mtxaudio.com/caraudio/headtohead/w7.cfm
Username: Taylor17
Kopperl, Texas
Post Number: 511
Go with the Jl.
Username: James1115
Wilton, Ct
Post Number: 848
I have heard both. I have heard both from the same amp JL 1000/1 in their factory built enclosures and the 9500 was no comparison to the w7. companies can claim what they want but I have tested both of them and also heard the same results from others. Is there a big price difference between the two yes there is but it makes the difference in this case.
Username: Hdubb
Farmington, Nm Usa
Post Number: 701
well the problem there is the enclosure, ive heard a mtx9500 in the sledgehammer box and it sucks! i heard a p3 out perform it in a ported custom box. so if you take them out of the box they will sound comparable to the w7
Username: Audio_fanatic
Mukilteo, Wa
Post Number: 41
Um i dont think so...maybe 2 9500 myte stand a little chance against 1 W7.
Username: Hdubb
Farmington, Nm Usa
Post Number: 709
i dont think that the 9500 will have the sq to match with the w7 but spl i think it will stand a chance
Thank you! Question i saw on ebay some a 12 inch Titanium by eclipse. Continuous Power Handling: 750W is this true? Music Power Handling: 1,500W.
Username: Hdubb
Farmington, Nm Usa
Post Number: 722
the 750 is the rms, but is underrated. this is an awesome subwoofer.
Username: Subfanatic
Walton, Ky Usa
Post Number: 202
it can take alot more..and this sub will easily give a w7 a run for its money
BabyBrock
if both subs were in snailshell enclosures, the 9500 will blow the w7 away and by a good margin. that is, if both subs were properly powered.
Username: Taylor17
Kopperl, Texas
Post Number: 516
No way!
I call b.s on that one!
Username: James1115
Wilton, Ct
Post Number: 877
yeah I am going to agree with Taylor. Your smokin something serious Baby!
Username: Suleman36
Post Number: 58
Go with the JL W7!!
Username: Jonathan_f
GA USA
Post Number: 3277
Notice that MTX compares it's 10" subwoofer to the 10W7. JL's W7 line increases subwoofer performance with size, while the MTX does not. The 10" MTX and the 10W7 perform similarly, but the 12W7 and 13W7 outperform the 9500. The JL also retains higher linearity than the MTX does, has higher surface area, and has more linear excursion than MTX once you get into the 12 and 13W7. It all translates into better SQ and SPL out of the driver.
Username: Rob315
Cuse, NY U.S.
Post Number: 130
hit the nail on the head there.....thats exactly right....only the 10's are comparable...after that, the MTX might want to bring one of his buddy's..
Username: Taylor17
Kopperl, Texas
Post Number: 529
I would also pick the Eclipse over the mtx
Walton, Ky Usa
Post Number: 203
well yea go with eclipse...the 12 inch ti takes the even the w7 slightly...would def beat a Mtx...i mean....if you can go witht hat..arent they cheaper anyways?
