What to do
Car Audio Help
I have a Ford Escape and I don't know much about car audio. I am going to get two JL 12 w3v2. I am wondering what type of box, headunit, and amp should I get?
Also is there anything else i should get?
Username: Hdubb
Farmington, Nm Usa
Post Number: 706
try the jl 500/1 or the 300/4. get a sealed box built to there specs. for a head unit look at alpine,eclipse, and pioneer premeir. how much are you looking to spend?
Car Audio Help
I am looking to spend $1000-$1500
Username: Hdubb
Farmington, Nm Usa
Post Number: 723
ok. you can get a nice alpine hu. off ebay for about 300. or a pioneer for about the same. either would be awesome. so you have a lil bit to spend on an amp. see if you cant get the 500/1 very good amp
Car Audio Help
Would I need two amps or would the 500/1 be powerful enough to power both subs
Car Audio Help
Would I need two amps or would the 500/1 be powerful enough to power both subs. Is the 500/1 a mono or multichannel amp. And which is better, mono or multichannel?
Thanks for the help.
Username: Taylor17
Kopperl, Texas
Post Number: 517
The 1 will push them fine.
Username: James1115
Wilton, Ct
Post Number: 876
alpine deck with the 500/1 to 2-12w3v2's in JL recomended enclosure will sound very nice.
