1 sub vs. 2 subs
Username: Sublime420
Ca Us
Post Number: 36
is it true that if you have two of the exact same subs, in identical boxes, and they get the same power, that having two only adds 3dB as opposed to having 1 sub? if so, is that a noticable difference?
Username: Rob315
Cuse, NY U.S.
Post Number: 121
no...if you double the power to the same sub you gain 3db's...doubling the subs also would give you even more db's
Ca Us
Post Number: 37
no. i mean like say you have two identical subs, and two identical amps. One amp, for one sub. how much louder would that setup be compared to one of those amps going to one of those subs?
Username: Rob315
Cuse, NY U.S.
Post Number: 124
more than 3 db's since you are doubling both the power and you are doubling the surface area
Username: Blownriv
OH USA
Post Number: 139
usually about 6dB. that is a very noticeable difference.
