Suggestions, suitable amp for eclipse 15" ti PRO
Username: Pineapplev
GREETINGS all the way from the uk!! i've bin trying to read around this problem,ur forums are quite educational!!! I still can't find out what a suitable amp would be for the Ti Pros,can anyone help? im prob. gona get it from ebay so price range is really anything upto $500.
Username: James1115
Wilton, Ct
Post Number: 736
from what I have heard about them any GOOD amp over 1000 watts will work well.
Username: Hdubb
Farmington, Nm Usa
Post Number: 687
look into the elemental designs nine.1. 350 bucks. it will do 1200 at 1 ohm. or the hifonics brutus bx2200. it does 2000 watts at 1 ohm. just some ideas
Username: Erik123456
Arlington, Tx
Post Number: 397
From what I have seen these subs need way more than 1200 watts
I have seen 1 ti pro 15 running off a 3000 watt RF amp
the titaniums can take more than 1000 so the pro can obviously hold a lot more the hifonics hunter suggested is a good choice for cost effectiveness
Username: James1115
Wilton, Ct
Post Number: 759
yeah I was just relaying what i had heard. Eclipse actually recomends 3000 RMS. a US amps DE 3000 would be insane!
Username: Taylor17
Kopperl, Texas
Post Number: 497
the us amp Jame's mintioned would work nice, but a little out of the price range, I think. The Rockford T30001BD would also work perfect, also out of the price range. The Hifonic's 2200 would be the best bet for that sub, good amount of power without paying an arm or a leg!:-)
Username: Sancho886
El Cajon, CA US
Post Number: 77
what about a harrison labs amp?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5726107019 %26&ssPageName=WD1V
if the link doesn't work put this item # in the ebay search bar. 5726107019
Thankyou everyone for all your imput, it was such a help!! i think i might go with the hifonics amp if i can find it, that rockford T30001BD looks like it would kick some A.S.S but way too over my budget.
NOOOW ineed you guys to explain to me bout this whole box concept. Eeerm ported?? sealed??? Size??? HELP YOU GUYS!!!
OOOh yea forgot to ask, let me just get this straight, a 1500 rms amp or similar value wouldn't be any good???
JUst found this amp ;
HIFONICS GENERATION XX HERCULES 2000 WATT AMP.
anyone know whether this hifonics is good ehough, reliable etc?
