What the best 12sub
Username: Thatboye18
I got a 1000/1 jl and a 12w7 i was lookin for something new that hits harder whats out there? {i dont want a 13.5w7}
Username: James1115
Wilton, Ct
Post Number: 780
Keep that amp and get a Brahma 15.
Username: Taylor17
Kopperl, Texas
Post Number: 501
If you are wanting to stay in 12's, and money is no object, git the Eclipse T's, should give the w7 a runn for it's money!
If you go with a 15 and money is no object go with Eclipse 15, or 18 T Pro.
Just realised that you have the 1000/1, that amp isn't really big enough to push a T Pro. it would do fine on the Eclipse T though.
What kind of enclosure are you currently using ?
The adire or Resonant Engineering Stuff would be cool. Elemental Designs, Kove Audio Armagedon...
Thanx i will look in to that
Username: James1115
Wilton, Ct
Post Number: 781
I would def go REXXX,Eclipse TI or Brahma,ID MAX.
Username: James1115
Wilton, Ct
Post Number: 782
Jonathan has that set up a ID max 12 with a 1000/1.
Username: Jonathan_f
GA USA
Post Number: 3252
Id Max is a great sub, but it isn't going to hit harder than the JL. In all honesty, all these subs in 12" form are so close to one another that in their optimal boxes you won't hear a huge difference besides the SQ. If you want more SPL, you'll need either more subs, a more SPL inclined sub like a Digital Designs sub in a ported box, or a larger (15") sub.
