Amp hookup with tweeters
Username: Bigwoody
Post Number: 7
I've got a tacoma ext cab which came with tweeters in the door. I want to replace the factory tweeters and front door speakers but I'm not going to hookup the back speakers. Should i buy a 2 channel amp and run the tweeters and speakers off the same channel or a 4 channel and run the tweeters and speakers off different channels? Thanks for all the past answers.
Username: Bass_lover
Post Number: 15
tweeters usually require some sort of crossover that connect up to the amplifier so that you dont damage them. Buy a 2 channel amp, by the sounds of it your not going to go hardcore with the set up so just buy a very basic amp to cover your needs I would only spend $80.00.
Username: Bigwoody
Post Number: 8
I'm probably going to get the infinity kappas, so they come with a crossover. Any suggestions on an amp for them?
