Sun Box in Tool box
Username: Chevyz71
I would like to know if you can build or be able to put a sub box into a toolbox for a 1996 Chevy Z71. If you have any anwsers please tell me. If you know how or where I would be able to do this please help me.
Username: Tbone
Post Number: 71
A toolbox in the bed of the truck? You would be better off with a box under the back seat of the truck.
Username: The_master
Bellmawr, Nj Usa
Post Number: 13
if you find a good sound shop they can do anything you want--if you can afford it-anything is possible.
Username: Its_bacon12
Post Number: 227
unless you have an 4th order bandpass box in there and a port running to ur cab, you pretty much wont hear anything if its in your toolbox...
ur much much better off getting something that will fit under the seat or behind ur seats even if it is only an 10 inch sub or 8 inch even
