Which sub should I go with?? Please
Computer nerd
I was thinking of 2 or 4 12s and I was going to decide between the IDmax V.3, Alpine type r, Vmax, or the Eclipse Aluminum or would you suggest another sub. Which one of them have the best spl. Which amp would you suggest. I am not looking for a massive massive amount of spl because they will be for a daily driver, but I want some.
Username: James1115
Wilton, Ct
Post Number: 598
all 3 of them are good choices. They will all get loud and sound good while doing it.
Username: Taylor17
Kopperl, Texas
Post Number: 427
All are grate subs, I would go with the Eclipse as my first choice. Second, git the Idmax.
Username: Jonathan_f
GA USA
Post Number: 3190
ID Max is the best sub you listed, then Eclipse Aluminums. The ID Max is better overall in SQ and SPL, it's on par with the JL W7, Eclipse Titanium, and Brahmas and X.X.X.'s. It actually displaces more air than a Brahma does. Just my opinion, though.
