Hifonics bx1500d sub
Username: Bassfreak596
Post Number: 79
i need a good sub for it..
should i go in for a single Eclipse Alums (12") or the RFt1 ?
the reason being i dont want to spend more than $300 for it..
any other suggestions ?
Username: Rob315
Cuse, NY U.S.
Post Number: 91
is that all you open to is those 2 subs?
Post Number: 80
any other subs that you can suggest ?
open to all brands ! under $300 subs..
Username: Rob315
Cuse, NY U.S.
Post Number: 95
alpine type x is a real nice sub but im kind of partial to alpine..anything your partial to?..looking for sound quality or bass??whats it going in?(vehicle)...stay on for a few and ill answer your questions
Username: Dankman
Granger, Indiana United States
Post Number: 19
I got the new eclipse aluminum and its great and its really loud without having to put more than 500 watts RMS to it, or go with those new MTX 7500 or 8500's, just some suggestions.
Post Number: 81
yeah.. i had thought about the Alpine type X.. but i didnt know how they sounded.
i m looking for a decent blend of spl/sq.. dont want the extremes..
well thats the problem Dankman.. i have the bx1500d amp.. and i ll have to put the coils in series for the 4ohm load.. it ll push 500w to the sub then. but then theres so much potential going waste !
Rob, i m partial to the eclipse.. but the new Alum series puts me off for its only 900w.. the older 8112 series was better i feel..
i dont know about the MTX. i can give max of 3cu ft for an enlosure. and only one sub fits in cause i need to carry a lot of stuff in the trunk.
thanks you guys.
Post Number: 82
hey ! hows the DD 3512 ? www.ddaudio.com
Post Number: 83
and the kicker L7 ? i heard that it has surround problems ?
Post Number: 84
hey rob, are you there ?
Username: James1115
Wilton, Ct
Post Number: 600
DD makes a very good product. I would recomend the ID max. I heard one of these on wednesday in a tahoe and holy SH&T. I have always been a big Image Dynamics fan but now even more then before. Here http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18803%26item%3D5749799045 %26%26 under 300 and will blow everything else away that you were looking at. Well thats my opinion I guess!
Post Number: 85
whoa.. all these choices are making me go crazy !
how does the eclipse Alum compare to the Type X or the id max ?
Username: James1115
Wilton, Ct
Post Number: 602
ID max is far superior to both of them. Then between the two othes they are pretty equal with the Type X being a little better in my opinion. Both type x and eclipse alum's are very good subs but not in the same class as the IDmax.
Post Number: 86
thnkz dude
Username: James1115
Wilton, Ct
Post Number: 606
no problem!
