Whats better with 900-1200 rms to it brahma or RE 3X????
Username: Armadalegq2000
im most likely to get a brahma but can only put around 1200 to it amp suggs as well???
Username: James1115
Wilton, Ct
Post Number: 605
both subs will do very well with that amount of power. If you drop under 1200 watts then I would go with the brahma. The REXXX needs about 1200 watts to sound very nice where the brahma reaches full excursion under 1000 in the right enclosure.
