Do i need a new alternator?
Username: Subfanatic
Walton, Ky Usa
Post Number: 179
would i need a new alternator if i ran a T1501D - MTX 1 Ch 1500 Watt Thunder Amplifier pushing 2 10 inch eclipse al's and an INTERFIRE Audio IB2900C amp pushing 2 10 inch kicker comp vr's
Username: James1115
Wilton, Ct
Post Number: 576
yes. You should. You would only be cheating your self if you didnt.
Walton, Ky Usa
Post Number: 189
what size alt
Username: James1115
Wilton, Ct
Post Number: 577
what is the rating on that interfire I couldnt find anything on that amp.
Walton, Ky Usa
Post Number: 191
go to www.interfireaudio.com and then from there on the left goto IB serious and i have the IB2900C ...its not that big of an amp but its def underrated i had it easily pushing 4 12 inch memphiss and it could have pushed more
Username: James1115
Wilton, Ct
Post Number: 580
well your pushing about 2000 watts there at rms. 2000/12 is 166.66 amps at peak volumes. I would suggest a 200 amp if you can find one.
