Can I fix my sub???
Evil.Commando
After inspecting my sub I noticed that the rubber on the outside that joins that cone to the frame type thing has perished and in some places broken. How can I fix it? Do I have to get it fixed professionally?
Username: Krijgy
Smithfield, Virginia United states
Post Number: 49
if your surround is damaged there is nothing you can do about it, it even voids the warrenty if you damage the surround. just cut your loses and buy a new one
Username: Jmloughrey
Farmington, CT
Post Number: 934
I beleive that you can use like silicone caulking or clear nail polish to patch a little hole or something in the surround....
