Which subs to go with?
Username: Urga21
West jordan , Utah Usa
Post Number: 11
i was thinking of going with 2 12 inch RE xx.x. This subs cost alot of money so i didn't know if there was a better sub out there to go with for equal or lesser money. Any suggestions would be helpful.
Username: Jmloughrey
Farmington, CT
Post Number: 933
if you go with 2 12" x.xx's make sure you power them with atleast 1000watts rms a peice as well as have a charging system that can handle the kind of draw that amp (amps) will want...
Username: Invain
Michigan United States
Post Number: 421
I really don't know what else you could get for the same price as 2 triple x's that would sound any better. If you did find something better, I'm sure the differences would be almost un-audiobal
Username: Rob_brown
Post Number: 127
if you are on a budget you might could try the ascendent stuff, but it would probably be best to go with the x.x.x's or the brahma's..
Username: Taylor17
Kopperl, Texas
Post Number: 399
Ya, I believe the Brhama's are a little cheeper, and close to the same sound.
