DVC question.
Bailz
I have a Cerwin Vega HED 12 DVC sub.
I know it as a rms handling of 200 watts.
I just don't understand what kind of amp to put up to it.
http://shopping.yahoo.com/p:Cerwin-Vega%20HED-12DVC%20Car%
that should have the specs.. it says 2/8 ohm.. so.. is it liky my choice of which to run it at? Seems like it'd be a lot cheaper to run it at 2 ohm, right? a 200 watt 2 ohn amp is cheap generally.
Thanks in advance.
Username: Taylor17
Kopperl, Texas
Post Number: 400
If you run it at 2 ohm's, the amp will put out a lot more power than it would at 8 ohm's:-)
If you only have 1 sub, then wire it in paralel down to 2 ohm's. When looking for an amp, just see what it put's out to 1 sub at 2 ohm's and match it with your sub.
