15" Brahma or 12w7 or RE HC 15" ??
Username: Terps297
Potomac, MD USA
Post Number: 15
running off of a JBL bp1200.1 which would sound the best/loudest?
what kind of box would these sound the best in also
would i need an alternator for this to run smoothly too? i have 600 peak wats out of another amp too
you should prolly look into getting a new alt...prolly bout a 180A.
that bp1200.1 is can draw 115A of current by itself, and i'm guessing that your 600w max amp is doing bout 300wrms...so it can prolly pull 30-40A.
personally, i would go w/ a brahma 15" or an x.x.x. 15", in about a 5 cu ft box tuned around 30hz.
