RE SE sub question...
Username: Scab12886
Post Number: 66
i was lookin to possibly get a 12 inch SE sub from reaudio. i saw on their site that it says its dual 4 ohm. does this mean i need an amp to put out 600 watts at 4 ohms? or am i wrong in saying that?
ThatGuyYouKnow
Dual 4ohm Voice Coil Configuration. Either an 8Ohm load or 2Ohm load by itself. So best bet is find an amp 600wRMS(dont need 600 really) rated at 2ohms.
ThatGuyYouKnow
Username: Scab12886
Post Number: 67
so 500-600 watts at 2 ohms is good?
ThatGuyYouKnow
500-600wRMS @ 2ohms is best yes.
