12" Alpine Type-R help
AJR9987
I have a dual 4-ohm 12" Type-R subwoofer, and I was wondering if the extra 50W from an MRD-M350 Alpine amplifier would be too much for it to handle. Thanks
Username: Taylor17
Kopperl, Texas
Post Number: 279
No it will be fine. I have actually hurd of people putting 500 watt's to that sub!
AJR9987
Thanks for your help. 500W?? Well, do you think that amplifier would be a good choice? What would you reccomend??
AJR9987
Username: Taylor17
Kopperl, Texas
Post Number: 281
If you wire it to 2 ohm's, you will git the 350 watt's. Perfect for that sub.
Username: Erik123456
Arlington, Tx
Post Number: 372
i have run a 250/1 slash amp on one type r with the gain turned down all the way and its still pounds
they dont need much more than 300 at all from what ive seen
Username: Kklagge
Post Number: 53
I have (2) 2omh DVC 10" type R's (have them wired to 1ohm) and I'm putting 450 into each and they sound excellent. They will definately handle more power than stated (possibly why the 2005's look exactly (except color)like the 2004's but say they can handle 500 instead of 300rms))
Username: James1115
Ct
Post Number: 328
they dont look like the 2004's they have the New type X surround.
Username: Bdonkersgoed
Ontario Canada
Post Number: 66
I had the MRD-M301 (350W RMS amp) coulpe with a 10" Alpine Type R at 2 ohms and it was fine :-) Until it was stolen that is :-(
No worries!
Bryan
Ontario Canada
Post Number: 67
I had the MRD-M301 (350W RMS amp) coupled with a 10" Alpine Type R at 2 ohms and it was fine :-) Until it was stolen that is :-(
No worries!
Bryan
Username: Rob315
Syracuse, NY U.S.
Post Number: 54
im going o be using 2 mrd m501's with 2 12" type r's(1241d). the amps are rated at around 600watts a piece.
David Lenz
I'm have a type r 15" for my graduation gift and i no nothing about this. i was just wondering what amp would be the best for this:-)
Username: Shimm57
i was just about to buy a 10'' type r and the m350 amp
should i spend a little more for the newer m301?
the power is the same but the newer one has some other qualities that im not sure of.
also, does the 12'' handle more power than the 10''?
Username: Invain
Michigan United States
Post Number: 413
Uhh, no the 12's and the 10's are the same power handeling. I'm pretty sure the 15" can handle more though, 750 rms I think
