Arc Kar Series Subs
Username: Jwbulger79
Florida
Post Number: 111
anyone have any experience with Arc's Kar series of subs? i've heard they're pretty decent for a budget sub. how might they stack up against the Shiva??
Florida
Post Number: 112
specs on the Arc 12"
http://www.arcaudio.com/arc-05/subwoofers/kar_12d4.htm
what specs are the best indicators of how much spl you will get? linear excursion? the Shiva has a one-way xmax of 16mm and the Arc has a 8mm one-way xmax. does this mean the shiva will destroy the arc in spl? not sure if i'm making any sense??
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 48
that doesnt mean everything... it does mean that the shiva will move more air... 8mm isnt very good at all though.... and im sure the shiva will destroy it though
Florida
Post Number: 113
cool. thanks trevor. the shiny looks of the Arc almost had me sold :-)
i'm down to two choices now - Shiva or Atlas
the retail on the atlas is $145. anyone know any place cheaper? can pickup the shiva for $125 shipped, so $$ might be the tiebreaker.
Username: Travisj
Look at the Elemental Designs stuff.
www.elementaldesigns.com. I have the 13Kv2 and I absolutely love it. Blows my buddies shiva out of the water. He ended up buying one too and replacing his shiva when he heard mine. 125 bucks.
Username: Invain
Michigan United States
Post Number: 422
Travis, what kind of enclosure do you have the 13Kv2 in?
