Opinions on Pryamid Hyper Pro Series 1000 watt 12's
Coolruning
I just bought two Pyramid Hyper Pro Series 12's.
There RMS power is 500watts
There Max Power is 1000watts
Single Voice Coil
4 OHMS
I plan on pushing these with a 1200 watt amp.
Put them in a Q-LOGIC non-ported box
If i need too, i can port the box.
Can anyone tell me if i wasted my money and will they sound good with what equipment i've got?
by the way, they are going in a 92 nissan sentra
2 Door
Thanks
Username: Byrumjr
Post Number: 72
What is the amp?
Username: Jmloughrey
Farmington, CT
Post Number: 913
...you wasted your money...
CoolRuning
actually its two seperate amps of 600 watts each, they are both kenwoods
Username: Cb9869
Post Number: 46
wasted your money, get it back fast.. although, u most likely bought it from a local person and they ripped you off, so *tear*
