Looking for a headunit under $110
J-dub94
anyone know a good unit for that price? anything will help.
Username: Erik123456
Arlington, Tx
Post Number: 374
try a low model 04 clarion
http://www.woofersetc.com/product.asp?0=248&1=249&3=2449
for like 30 bucks more you can get on that plays mp3
Username: Nnives
Post Number: 10
Panasonic CQ-C1120U is in your price range. It is not the best but it is sort of what you are looking for. You can buy it anywhere from $70-100. Depends on where you are looking. You can also go on Ebay and look at car stereo and check out the buy it now prices. You just have to take the time to compare and contrast on crutchfield.com once you get it down to the head units you want.
Username: James1115
Ct
Post Number: 316
I would look on ebay for an old Alpine.
Username: James1115
Ct
Post Number: 317
kmag
go with kenwood, jvc, or pioneer. used is tricky, it might be good, it might die tomorrow. i would avoid it at this point. I assume that you dont have money for speakers or amp so you will want some kind of eq settings, pioneer's ezeq allows the most adjustments. most stereo equipment goes on sale in the spring as new models are introduced, so there will be some decent sales soon.
Username: Bnh142
Post Number: 51
I bought an alpine used and ended up having problems with it. I got a CDA9811 for around $135 but it has some issues.
Username: Rob315
Syracuse, NY U.S.
Post Number: 64
i have a kenwood kdc 5019 for sale if your interested. brand new for 125.
