How to hook up speakers
Username: Nigeltufnel3
K, I just got an amp, amp kit, and a sub. I am just wondering how to hook up the speakers to the speaker outputs on the amp. Do you just push the speaker wire in there and screw it down, or do you need some spade connectors or something? Thanks!
Username: Byrumjr
Post Number: 69
I like to solder round washer clips on my wires. I think it make a neater job and less chance of some wires hitting the screw next to it. I have just put the wire under the screw before but there is more of the chance of hitting the other screws.
