Hooking up 2 orion hcca 225g4
Username: Joebruce
KY U.S.A.
Post Number: 28
Could someone make a list of everything i will need to hook up 2 of these amps.I would like to use all knu konceptz wires and accessories.Would i need a distrubution block run a 0/1g that splits to two 4g? Or one 4g that splits to 2 8g?Thanks for your help.
Username: Carguy
Post Number: 1302
If you want to wire it for the future, then go with 0 gauge, but 4 gauge is good enough for 2 225G4 amps.
You have one of the best amps ever made. I have 250G4 and it pounds with crystal clear sounds.
Very good choice.
If your amps accepts 4 gauge wire, then use that, if not 8 gauge will do just fine.
