Ok tell me how exactly
Username: Perrydog
Flint, Michigan USA
Post Number: 54
ok tell me exactly how to split the power calbe and what do i need, tell me how to split the ground and what do i need and tell me how to split the remote calbe and what i need and plz help me
Username: Hdubb
Farmington, Nm Usa
Post Number: 532
to split the power cable you will need a power dist. block. ok before i go any further why do you need all this stuff split? if i may ask. are you trying to run 2 amps? let me know and i will try to help more.
Username: Perrydog
Flint, Michigan USA
Post Number: 57
ya i wanna run 2 amps but dont want to have to run another set of cables, i really would appreciate it if you guys helped me out on this
Username: Solacedagony
New Jersey US
Post Number: 241
You will need a distribution block like Hunter said. Although you'll probably want to run 0/1 cable from your battery to your dist. block, then run 2 or 4 gauge in short distances from your dist block to the amps. You will have to run extra wiring and another set of RCA cables, regardless.
